Activity Forums Adobe Audition batch file conversion
  • batch file conversion
    Posted by Scrimski on February 1, 2007 at 12:36 am
    Hi everybody,
    I got a massive amount of 32 bit, 3 channel *.wav files which I need to convert into 16-bit aiff or wav files.
    When I import the source file manually it is split up into three files, each for one channel. Channel #1 and #2 are empty, the data is stored in ch #3. When I use the batch function for conversion Audition only opens and converts the first channel, which is quite useless.
    Where do I go wrong, is there any solution, maybe a script for that purpose?
    Thanks in advance
    scrimski
    Scrimski replied 19 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
