Activity Forums Adobe After Effects Batch Fade In and Out
  • Batch Fade In and Out
    Posted by Johnny Knox on December 10, 2008 at 2:21 pm
    I am in the process of editing about 40 – 50 hours of home VHS video and converting it to DVD for Christmas. Right now I have all the clips in .mpg format which I ripped strait from the DVD. I could go through one by one in premiere and add fades, but does anyone know of a way where I could ask After Effects to add a 2 second audio and video fade in and fade out to about 100 video files.
    Anyone got any idea, I would really appreciate any insight?
    Mark Likosky replied 14 years, 5 months ago 4 Members · 5 Replies
  • Adriano Moraes
    December 10, 2008 at 3:44 pm
    Well I would put all the layers in the begginin’ of the comp.
    Hit CTRL+A to select all.
    Hit ALT+SHIFT+T to add a opacity keyframe. Hold ALT+SHIFT and hit the right arrow key 6 times to move those KFs 2 seconds ahead. Set another keyframe at the beggining, this time changing it´s value to 0%.
    Then go to the end of the layers. Hit ALT+SHIFT+T to add a opacity keyframe. Hold ALT+SHIFT and hit the left key arrow 6 times to move those KFs 2 seconds back. Again set another keyframe at end, this time changing it´s value to 0%.
    Then right click any layer and chose keyframe assistent>sequence layers
    Then chose the right ovelap value.
    It´s the easyest way I can think of and I do it all the time. If the clips are of different lenghts you can go to the last one and hit CTRL+A then ] to align them all at the end before setting the out opacity values. Then back to the beggining and hitting [.
    Act like a robot and it all will come out nicelly.
    Hope I was of some help.
    Cheers.
    ninguem
  • Adriano Moraes
    December 10, 2008 at 3:47 pm
    Something came to my mind after I hit post.
    You can simply select all and go keyframe assistent>sequence layers and on the dialog box where it says transition chose dissolve front layer.
    Some adjustments and you´re good to go.
    Easier that way ain´t it?
    Did it work?
    Cheers.
    ninguem
    ninguem
  • Eric Bradberry
    December 11, 2008 at 7:49 pm
    why not just add frames of black above intro and outro and add a 9 fram e dissolve on each. duh
    Eric Bradberry
    Avid Editor
    Mix it down!
  • Mark Likosky
    February 22, 2012 at 12:48 am
    I’ve found presets that I like but I’m having a tough time saving one to automatically fade out at the last 7 frames of any given assigned clip.
    I tried saving it from the time line but it just fades in to white in the beginning. I only want it at the end.
  • Mark Likosky
    March 16, 2012 at 7:37 pm
    I was able to add Easy Ease Out and save that as a preset but how do I automatically add this to the last 7 frames to any given clip?
