Activity › Forums › Apple Final Cut Pro Legacy › batch exporting to compressor from the timeline
  • batch exporting to compressor from the timeline
    Posted by Chad Tingle on September 10, 2010 at 11:50 pm
    I am working on a commercial with 4 different versions of the edit in the same timeline. Is there a way to send these to a batch in compressor. I do it from the browser all the time and I’m curious to know if this works from the timeline as well
    Chad Tingle
    Producer/Editor
    Chad Brewer replied 16 years ago 2 Members · 1 Reply
  • Chad Brewer
    September 11, 2010 at 2:05 am
    There may be a better way, but I set an in/out in the timeline for the specified clip, select in/out, then drag that in to the bin and rename it. I do this for every select from the timeline and then you see them with the new in/outs different from the master clip. Once I have the multiple new clips in the bin, I batch send them to Compressor like you’re used to doing.
    Chad Brewer
    Senior Tape Operator/Engineer
    TeleVersions
