Activity › Forums › Apple Final Cut Pro Legacy › Batch Export?
Batch Export?
Posted by Tresynful on November 18, 2007 at 12:23 amHi All,
Is there a way to batch export clips?
I’m working with a video I need to export into 60 second clips..Thanks
Russell Lasson replied 18 years, 10 months ago 3 Members · 2 Replies -
Tom Meegan
November 18, 2007 at 8:00 amSelect what you want to batch out in the Browser.
Right Click and choose Batch Export.
Use the dialog box to set the settings and destination.
Hit export.
Russell Lasson
November 19, 2007 at 8:43 pmIf everything is on the same timeline, then just select the range you want with in and out points and then send it to compressor. Don’t submit the batch yet. Now select the next play range and export it to compressor again. Each compressor item will keep the play range that you selected.
You might also want to put markers at the points where you set the in and out points just in case you need to export it again, it will make it easier to find the sections that you want.
-Russ
