Activity Forums Apple Final Cut Pro Legacy Batch Export Workflow
  • Batch Export Workflow
    Posted by Greg Ball on January 30, 2009 at 3:48 am
    I’ve shot 40 individual people giving 1 minute comments. I need to provide the client with 40 individual high quality QT files he can turn into flash files. I’d like to edit each one and then batch export them. My questions is do I need to create 40 sequences and then batch export all of the sequences, or is there a better workflow?
    What kind of QT files and codec should I give him for the best quality for him to convert to flash? Probably on a windows environment. Thanks.
    Rafael Amador replied 17 years, 7 months ago 2 Members · 3 Replies
  • Rafael Amador
    January 30, 2009 at 10:05 am
    Or you make 40 sequences or you make one sequence and export the 40 clips from the sequence.
    What kind of footage are you using?
    Do you intend to do some CC or so, or you only go to cut the rushes?
    Rafael?
    http://www.nagavideo.com
  • Greg Ball
    January 30, 2009 at 11:46 am
    Hi Rafael- These are from Beta SP 8 bit uncompressed. Some are two camera multi-clip interviews. But the rest are talking heads, fade up, add titles lowerthird, fade out with some minor CC.
    My hope would be to edit each clip and then batch export them while I’m off doing something else. Quality is key for these guys to be able to make flash files from the best QT I can give them
  • Rafael Amador
    January 30, 2009 at 12:34 pm
    Hi Greg,
    I would edit in a 8b Unc sequence and I would export to ProRess HQ. Setting “High Precision” rendering.
    Top quality, small files and the PC people can open them with the free reader.
    Rafel
