Activity Forums Apple Final Cut Pro Batch export to multiple settings
  • Batch export to multiple settings
    Posted by Bret Williams on November 18, 2014 at 4:41 pm
    So is this something new? If I’m adding a destination for export, I can shift click multiple compressor settings and it comes into FCP X labeled a “compressor bundle.” Choosing that for export instantly ques up a batch export to all the settings in the bundle.
    I did not know that.
    So if normally you export a 720p, a 1080p, and an SD you can create a compressor bundle export setting and BAM!
    James Ewart replied 11 years, 10 months ago 4 Members · 4 Replies
  • Jeremy Garchow
    November 18, 2014 at 5:26 pm
    Not new, but very useful.
    You can also add a bundle right in the Destination prefs, and it doesn’t have to be Compressor settings.
  • Nick Ring
    November 18, 2014 at 7:42 pm
    It’s been a long time since I tested it, but I used to regularly export to DVD and Vimeo. If I created a bundle that created the DVD first, it would stop the process at the point of the dialog box for making another DVD copy. Not helpful. I sent feedback, but I don’t think anything has changed on that front. However, for exports not involving DVDs, it’s been helpful.
  • Bret Williams
    November 18, 2014 at 11:10 pm
    I guess I never needed it or noticed it. I just discovered it today as I was replacing my compressor settings after a clean install of Yosemite and everything else. So it was actually NOT doing what I wanted in this case.
  • James Ewart
    November 20, 2014 at 7:53 am
    BAM indeed. Where has that been hiding? Thanks Bret.
