Activity Forums Apple Final Cut Pro Legacy Batch export script – export multiple audio clips fromthe same timeline
  • Batch export script – export multiple audio clips fromthe same timeline
    Posted by Daniel5000 on August 15, 2006 at 7:19 pm
    Hello All
    I have an interesting job coming up that looks to be rather repetitive.
    Example:
    35 min clip in a sequence timeline
    Daniel5000 replied 20 years, 1 month ago 2 Members · 2 Replies
  • Steven Gonzales
    August 15, 2006 at 7:36 pm
    I haven’t tried this, but I think you could cut the audio at each marker in a duplicate sequence. Then select all audio in the sequence, and drag to a new bin. Give each clip a slightly different name (so when you export, you don’t get a filename conflict).
    Then from that new bin, you could select batch export, and set to .WAV and 44,100 khz. Also, select “use item in and out”.
    You should have individual audio files in Wav format of the portion clipped in the timeline.
  • Daniel5000
    August 16, 2006 at 9:21 am
    Thanks Steven
    I gave it a try and found out that after you drag all the edit to a new bin, I have to right click and make independent clips. Otherwise I can rename the individual files.
    Unfortunately, once the files go into the new bin they also do not arrange them self in a descending order. So I can manage which audio clip is which.
    Alternatively I can drag each edit over to the new bin one by one and rename
