Activity Forums Adobe Premiere Pro Batch Export Multiple Sequences
  • Batch Export Multiple Sequences
    Posted by Shawn Lloyd on July 30, 2011 at 4:40 pm
    I’m really enjoying getting back into Premiere again, but I’m finding some glaring holes. I’m using PP5 and I need to batch export 100 individual seqences from one project. Unless I’ve missed something or they’ve added it in 5.5, there doesn’t seem to be a way to do it. I tried a work around where you open the project with Media Encoder, which works, but it doesn’t preserve the naming structure of the sequences, which is critical to the project.
    Anybody know any tricks?
    Shawn Lloyd replied 13 years, 1 month ago 9 Members · 16 Replies
  • 16 Replies
  • Ann Bens
    July 30, 2011 at 10:58 pm
    Try it the other way around.
    Add Premiere Pro Sequence to the Media Encoder.
    Or have a look at watch folders.
    https://help.adobe.com/en_US/mediaencoder/cs/using/WSb8e30982e628fbec-a5468e9131255217e9-8000.html
    Adobe Certified Expert Premiere Pro
  • Shawn Lloyd
    August 2, 2011 at 12:37 am
    Thanks. Yes, I already tried that and it seems to rename all the files it outputs after the project name instead of the sequence name. Unfortunately, all the 100+ sequences, and subsequent output files have very strict naming conventions. So unless someone knows a way of preserving those names when importing a PPro project into AME I will just export each one by hand, which isn’t the end of the world.
  • Alex Udell
    August 2, 2011 at 8:55 pm
    In PPro,
    can you multi-select Sequences in the project panel
    File>Export AME
    then CHoose Send to Queue?
    Just a guess….I’m not in front of it….
    Alex
  • Alex Hawkins
    August 3, 2011 at 1:24 am
    Shawn I just did this the other day with 18 sequences and it worked fine.
    I just opened up AME and went File/Add Premiere Pro Sequence and they all came in with the correct name and were automatically outputted to my default folder I have selected in the preferences.
    Then it was just a matter of highlighting them all and changing the codec format to the preset I had already made.
    Is this really not working for you?
    Alex Hawkins
    Canberra, Australia
  • Jon Barrie
    August 3, 2011 at 1:29 am
    Hi Alex,
    I think what is wanted here is to bypass having to open PPro at all and just use AME to import the Sequences. There is an inconsistent workflow when doing this whereby the sequence name is not used as the filename, but rather the project name for all sequences within that project.
    It is not so much a “bug” as not consistent with expected workflow. I am sure it will be resolved in upcoming versions, but currently with 5.5 the issue remains.
    The only way to work with sequence names as default filenames is as you point out – exporting from PPro.
    – JB
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Alex Hawkins
    August 3, 2011 at 1:36 am
    Shawn sorry my bad. I posted too hastily.
    Yes this is something that they have fixed in 5.5. I just realised you were on 5.
    5 imports all sequences as the project name plus an increment whereas 5.5 will import all sequences with their discreet name intact.
    Is this enough of a reason to upgrade?
    Alex Hawkins
    Canberra, Australia
  • Alex Hawkins
    August 3, 2011 at 1:38 am
    [Jon Barrie] ” I am sure it will be resolved in upcoming versions, but currently with 5.5 the issue remains.”
    Jon are you sure about this?
    Seriously I did this yesterday without opening PPro at all, using AME 5.5.
  • Shawn Lloyd
    August 3, 2011 at 4:29 am
    Thanks for all the responses guys. Yes, between that and the warp stabilizer I do think I’ll upgrade. One other cool thing… their team actually wrote me back after I requested this feature through there official “feature request” page (not knowing it was in 5.5). I don’t know how many features and ideas I mentioned to the Apple FCP guys over the years and never received so much as a peep. It’s the little things right? Very cool of Adobe, I thought.
  • Jon Barrie
    August 3, 2011 at 11:23 am
    Hi Alex,
    My apologies you are correct, it has been fixed in CS5.5
    JB
    Jon Barrie
    aJBprods
  • Ryan Sarver
    September 14, 2011 at 12:27 pm
    So when I open up the project in AME I see the projects all named correctly however I have tried every keyboard shortcut I can think to select multiple sequences but am only able to add 1 at a time. This isn’t much help if I have to reopen the project and select each sequence individually. I am sure I am doing something wrong here but could really use the help.
    Premiere CS5.5
    Mac OS X 10.7
