Activity › Forums › Apple Final Cut Pro Legacy › Batch Export Markers as JPEG’s
  • Jerry Hofmann
    June 4, 2007 at 6:36 pm
    You need to create subclips from the markers (will be a clip from marker to the next marker) to export them as JPEG movies. The will retain the names you’ve given the markers.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Rory Hinds
    June 4, 2007 at 6:55 pm
    Hi Jerry
    Thanks for your help.
    I’m trying to create stills from frames and have a 100 to do so want to batch export the markers as still frames.
    Any ideas why it won’t work?
    Regards
    Rory
    Rory Hinds
    mine
    http://www.minefilms.com
  • David Bogie
    June 5, 2007 at 2:34 pm
    What have you tried?
    I don’t have FCP6 yet but are you trying to do the same thing you used to do in FCP5+?
    It still works on FCP5.
    bogiesan
  • Rory Hinds
    June 5, 2007 at 3:19 pm
    Yeah I’m doing what I would do in FCP5 and it seems broken in FCP6 or they have change the way you do it?
    Rory Hinds
    mine
