Activity › Forums › Apple Final Cut Pro › Batch Export in El Capitan
  • Batch Export in El Capitan
    Posted by James Ewart on November 4, 2015 at 12:59 pm
    I’m in El Capitan.
    So I’m doing a “batch export” (I know I know it’s not really a “batch” batch) insomuch as I have selected a default export option and a bunch of projects.
    However (and I don’t think this was the behaviour in Yosemite) the actual file names do not show up in the background tasks window – just the file format selected.
    i’m sure in the past I would check the background window in case I was needlessly exporting duplicate projects by mistake and then simply delete one of them.
    Am I mistaken?
    James Cude replied 10 years, 10 months ago 5 Members · 7 Replies
  • 7 Replies
  • Bret Williams
    November 4, 2015 at 1:01 pm
    You are mistaken. It was always (stupidly) this way.
  • James Ewart
    November 4, 2015 at 1:35 pm
    Thanks Bret.
    Memory playing tricks with me.
    First comment about El Capitan is exporting seems much slower out of FCPX to me. I have not done a scientific test. I measure it on the personal boredom tedium scale.
    I know I should be getting on with other stuff.
  • Mark Smith
    November 4, 2015 at 4:02 pm
    so How did you set up your batch for export?
    I tried this the other day with 5 projects that all needed to be exported and I could only select one project at a time and then share to a destination.
    Did you drag project files into compressor or something like that?
  • James Ewart
    November 4, 2015 at 4:17 pm
    I got it from Ripple Training and it’s not quite real batch export but doesn’t take any more time.
    Yes very annoyingly you cannot select a whole bunch of projects and export them with one set of commands.
    But you can set one export options as default in preferences and then just Command E all the projects one at a time. Once you have selected a destination for the first export the others all follow to the same place.
    So it is quite fast.
    NB
    The problem with this system I have found is if you want to then batch export again in a different format and change the default export in settings it screws up the previous batch export.
  • Bret Williams
    November 6, 2015 at 12:44 am
    Yep. After the first one, it’s just cmd E, enter enter. Cmd E, enter enter. However I have done some 40+ exports where it’s a pain. But for 5 or so not a problem.
  • Don Walker
    November 6, 2015 at 4:08 pm
    [James Ewart] “First comment about El Capitan is exporting seems much slower out of FCPX to me. I have not done a scientific test. I measure it on the personal boredom tedium scale.
    I’ve noticed this also. On Sunday afternoons, I am exporting a 1:58;00 mp4. What used to take 35 minutes, now takes over an hour!
    don walker
    texarkana, texas
    John 3:16
  • James Cude
    November 9, 2015 at 10:18 pm
    note you can set up scripts to automate this like with automator, keyboard maestro, or something like FCPXporter https://www.youtube.com/watch?v=DKFZL7jwaS8
