Activity Forums Apple Final Cut Pro Legacy Batch Export Clips from timeline??
  • Batch Export Clips from timeline??
    Posted by Jared Kay on May 21, 2010 at 12:40 pm
    I have over 100 separate physician interviews in need of web export. I have created sequences (timelines) labeled Day1, Day2, etc… with 5-10 separate interviews on each timeline.
    I am now needing to export these to a web capable format..
    I have scoured the web for a solution to a batch export option, and so far, no luck..
    I can’t be asking too much from final cut, right?
    Specs:
    Final Cut Pro 6
    Canon 7d H264 (1080, 30fps)
    Jared Kay replied 15 years, 10 months ago 3 Members · 4 Replies
  • Arnie Schlissel
    May 21, 2010 at 2:50 pm
    Look up “Batch Export” in your FCP manual. It will have all of the steps you need to do this.
    You can also export your sequences to Compressor as a batch. Select them all, right click & choose Export via Compressor.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Jared Kay
    May 21, 2010 at 8:09 pm
    A standard batch export is no problem…
    The issue is batch exporting multiple separate clips from a single timeline…
  • John P isaza
    October 27, 2010 at 11:08 pm
    I have the same question did you find a way to do it?
  • Jared Kay
    November 5, 2010 at 1:15 pm
    I did find a round-abut way…
    I now copy/paste each segment to a new sequence… and then highlight and right click on all sequences in the bin, and selecting “batch export”
    For instance…
    My Timeline:
    ///segment1//// ///segment2//// ///segment3////
    New Sequence 1:
    ///segment1////
    New Sequence 2:
    ///segment2////
    …etc
    Hope this helps….
    Jared Kay
    https://www.amplified-media.com
