Activity Forums Adobe Premiere Pro Batch export all clips on timeline as seperate videos
  • Batch export all clips on timeline as seperate videos
    Posted by Allard Depallerd on January 22, 2014 at 8:42 am
    I have a timeline with 30 differtens clips, with no transistions or anything.. just 1 after another.. I want to export all these clips on the timeline, as seperate videos all at once. Is this possible?
    Same settings for every clip..
    Or if not..how can I easily achieve this? Maybe through speedgrade or resolve?
    thank you!
    Allard Depallerd replied 12 years, 8 months ago 2 Members · 5 Replies
  • Lenny Greaster
    January 22, 2014 at 3:25 pm
    I would send to After Effects, separate each clip to it’s own layer and run a script to send each layer to the render queue.
  • Allard Depallerd
    January 22, 2014 at 6:08 pm
    ok so no way of doing this in Premiere then? Hmmm ill just use resolve then.. it has the fuction to output the timeline to seperate files…
    thanks!
  • Lenny Greaster
    January 22, 2014 at 9:00 pm
    You could try the Project Manager. Select only the timeline you want in the source, exclude unused clips, collect and copy to new location. They will be in the format they were originally (and some long gop formats won’t be trimmed). You could then take the new folder of assets and batch them in Media Encoder. Sorry if it’s not practical – just spit-balling 🙂
  • Lenny Greaster
    January 22, 2014 at 9:05 pm
    One more thing – you could right click on each clip, select nest and in AME select all the new sequences. Then batch render them out as you wish.
  • Allard Depallerd
    January 23, 2014 at 11:20 am
    Hmmm that sounds like a good alternative.. ill try that one…
    Thank you for your help Lenny!
