Activity › Forums › Apple Final Cut Pro › Batch export
Batch export
Posted by Michael Sanders on July 2, 2014 at 5:22 pmCan someone write, in the next few mins if poss, a programme that takes the FCP X XML of an event or preferably a keyword collection and converts that to a compressor batch please..
Michael Sanders
London Based DP/EditorOliver Peters replied 11 years, 10 months ago 4 Members · 4 Replies -
Jeremy Garchow
July 2, 2014 at 7:01 pmAnd while you’re at it, take a sequence XML, compress all clips with two second handles, and then send a new Project XML back to FCPX.
K thnx bye
Jeremy Garchow
July 2, 2014 at 9:28 pmBITC stored in separate video track in the same video container with alpha channel for user selectable on/off.
Oliver Peters
July 3, 2014 at 12:21 am[Michael Sanders] “preferably a keyword collection and converts that to a compressor batch please”
It’s a bit convoluted, but here’s a way:
1. Select all clips – full length – no mark in/out, unless you want to shorten
2. Edit those to a new sequence (FCP X project)
3. Export an FCPXML for the sequence
4. Launch ClipExporter (free), load the FCPXML, select QT option and target folder
5. Run ClipExporter, which then copies the QT files to the target folder (each clip within a subfolder)
6. Use the folder’s Find bar to select .mov files in the target folder, which will isolate the individual movies
7. Drag these one level higher, so they are now out of their folders
8a. Load Compressor and run these as a batch
8b. Or – create a Compressor Droplet and drag these files to the Droplet to run the batch
9. Delete the QT copiesNote: If you click the Q icon button for QT twice, it turns into Qr and enables ClipExporter to write QT reference files instead of full copies.
– Oliver
Orlando, FL
http://www.oliverpeters.com
