Activity › Forums › Avid Media Composer › Batch Export
Batch Export
Posted by Scott Davis on April 20, 2011 at 11:38 pmNick Hrycyk replied 15 years, 4 months ago 3 Members · 2 Replies -
Steve Pankow
April 21, 2011 at 12:34 amJust highlight them in your bin and export them. Double-check your tracks and marks settings though.
Nick Hrycyk
April 21, 2011 at 9:47 amNot sure in 5.x but hiliting a bunch of clips/sequences and selecting ‘export’ used to require you to hit enter several times after each export. To avoid this, select your required ‘export’ settings in your Project settings, making sure it is the setting with the check mark, then hilite the clips/sequences you want to export then drag them to the folder you want to export to and go have a beer! You are actually dragging from MC to a folder in either Finder or Explorer.
Nick Hrycyk
Digital Image Studios
