batch export
Posted by John Culleton on June 3, 2011 at 2:15 pmis it possible to batch export clips? any scripts available?
Mike Kujbida replied 15 years, 3 months ago 3 Members · 5 Replies -
Aleksey Tarasov
June 3, 2011 at 3:24 pmVegas Pro contains Batch Render script (Tools > Scripting), which can render current project to multiple formats (using selected render templates). Is this what you are looking for?
Mike Kujbida
June 3, 2011 at 3:51 pmCreate regions around each section (highlight it and press ‘r’ to create a region) and run the script that John mentioned.
John Culleton
June 3, 2011 at 4:42 pmand how good is that! now, if only i could keep the clip names?
Mike Kujbida
June 3, 2011 at 4:47 pmNot working – Region text to be the file name in a batch render
Be sure to read the entire thread carefully as there were several corrections mentioned.
