Activity Forums Apple Final Cut Pro Legacy Batch editing clip duration.
  • Batch editing clip duration.
    Posted by Dananderiq on December 11, 2006 at 10:28 pm
    Hello. I’m working on a live actio, stop motion piece with a lot of stills (obviously). I want to play around with different speeds of Frame’s per second. I’ve already got my clips in a sequence, and rendered them out and have a bunch of effects, filters, and motion keyframes. Now I just want to try different speeds. Right now, my default is to import stills at a length of 2 frames.
    Is there a way I can batch cut all these stills to 1 frame? Or batch them to all add 1 frame? Once the stills are already in the sequence?
    I’m thinking FCP might have a feature similar to “paste attributes” that would do the trick. Any help would be much appreciated. Thanks!
    Dananderiq replied 19 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
