Activity › Forums › Apple Final Cut Pro Legacy › batch digitizing at different compression
  • batch digitizing at different compression
    Posted by Morris Zagha on June 7, 2006 at 10:15 pm
    Hi, I know I’m having a brain freeze on something obvious, but I’m not able to solve it right now.
    An assistant editor digitized several tapes of betaSP footage uncompressed and I need to recapture it at DV/DVCPRO-NTSC. I’ve done this in the past by marking the clips offline and deleting the media, then re-batch capturing the tapes. But the now “offline” logged clips are recapturing at the same uncompressed file size, no matter what I set the “setup” at. The bin of offline clips has “uncompressed 8-bit 4:2:2” in the compressor column and I think that when it’s batch digitizing it’s defaulting back to what it was first digitized at. I don’t see a way to delete the setting of the first capture.
    I’m sure that I don’t need to relog the clips and start from scratch, but I’m not sure how to easily get the clips recaptued in the proper codec.
    Advice?
    Thanks – M
    Morris Zagha replied 20 years, 3 months ago 2 Members · 2 Replies
  • Walter Biscardi
    June 7, 2006 at 10:42 pm
    When you go to Batch Digitize, change the compression setting in that Batch window.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Morris Zagha
    June 8, 2006 at 12:16 am
    Oy! Yes – I knew it was a simple check box. Thanks so much,
    MZ
