Activity Forums Avid Media Composer Batch Digitize
  • Batch Digitize
    Posted by Duane Fulk on May 16, 2008 at 2:10 pm
    I’ve been trying to figure this one out for years. I have tapes with camera A and camera B footage all with the same timecode. If I digitize all of the shots I need from camera A is there a way to copy the bin contents to another bin and then batch digitize that bin with the footage from the camera B tape? When I’ve tried it the camera A footage is wiped out because AVID thinks I’m trying to batch the footage I’ve already digitized.
    Any suggestions?
    Duane
    Duane
    Dylan Reeve replied 18 years, 4 months ago 5 Members · 5 Replies
  • John Cuevas
    May 16, 2008 at 3:49 pm
    There may be another better way, but this works for me.
    Open up the digitize tool. Create Tape A & Tape B. Now log all the shots for tape A, but don’t digitize. Highlight all the clips and Cntl-d. Take these new clips into a new bin and close first bin.
    Highlight all the clips in new bin. From the “clip” pulldown on top, hit “modify” and then pulldown “set source”. Change the source to tape B. Avid will give a few warnings, hit yes.
    Now batch digitize.
    Johnny Cuevas, Editor
    http://www.ckandco.net
  • Bobby Calautti
    May 16, 2008 at 6:39 pm
    Sounds like that workflow works. I just do not know why you would log clips from Tape A, and capture media from those logged clips off of Tape B. Why not just log Tape B to begin with?
  • John Cuevas
    May 16, 2008 at 7:04 pm
    Can’t answer for him, but for me it’s because I’m editing a multi-camera shoot and want to have the corresponding clips from both cameras.
    Depending on the shoot, it can be time-consuming to have to log everything twice. Really gets takes a ton of time, say when you have to digitize 6 shows of footage—so only having to log once saves a bunch of time.
  • Terence Curren
    May 17, 2008 at 3:15 pm
    After logging the “A” camera, just copy the slips to another bin and first unlink them (CTRL [PC] CMD [MAC] + Shift and the “relink” file menu will change to “unlink”), then select them all and choose “modify” and give them the “B” camera tape name. Batch capture away.
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
  • Dylan Reeve
    May 19, 2008 at 2:10 am
    And one more option – export and ALE and do a find and replace on the tape name, then reimport into a new bin.
    So many solutions… 🙂
