Activity Forums Apple Final Cut Pro Legacy Batch-Digitize of Sequenze
  • Batch-Digitize of Sequenze
    Posted by Bernd Fütterer on November 29, 2009 at 7:16 pm
    I’ve got an 15 Minutes-Sequenze and want to batch-digitize the material into a better quality. FCP tells me, that the digitizing-material will be about 4 hours! The reson is, that he want’s to capture every complete clip, not only the shot extraction posted in the timeline. What can I do, that my digitizing-material will only be 15 Minutes, like my timeline?
    Thanks a lot for your answers!
    Jerry Hofmann replied 16 years, 9 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    November 30, 2009 at 2:41 pm
    It may be longer than 15 minutes if there’s sync sound that is part of a split edit, but here’s the procedure:
    1. select the sequence and right click on it to select “media manager”
    2. Media manager opens and you select the following: “Create Offline”, “delete unused media (add handles if you want) and select the format you wish to recapture…
    3. select “create new project file, and then hit go…
    4. A new project file opens with clips and sequences “offline”.. batch capture that sequence or set of clips.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
