Activity › Forums › Apple Final Cut Pro Legacy › Batch digitize error?
Posted by Gilligan on June 15, 2005 at 4:42 pmHello,
I
Mike Hennessey replied 21 years, 3 months ago 2 Members · 1 Reply -
1 Reply
Mike Hennessey
June 15, 2005 at 5:54 pmTry doing one clip at a time. It may be that you have a time code change from one shot to another on the tape. If FCP is trying to cue up to digitize and the pre-roll drifts into the previous shot with the time code jump it will get lost and try to reque. This could mess up the hole batch. The trick is finding out witch clip is the culprit.
Good luck
