Activity Forums Apple Final Cut Pro Legacy Batch Digitize continues to Unexpectedly Quits!
  • Batch Digitize continues to Unexpectedly Quits!
    Posted by Carlos Prio on January 5, 2006 at 11:33 am
    day from ****!!!
    Setup-
    Dual 2.0 mhz G5 w/ 2.5 megs 160G Sys. 10.4.3
    Decklink HD w/ Multibridge SW 5.2.4
    2- La Cie 1 terras via 800FW
    Workflow-
    1. Logged 3 tapes worth of material into 1 bin
    2. Set Batch Capture last night
    3.captured tape 1 successfully
    4.put tape 2 in the deck
    5.started digitizing tape 2
    6.at around 07:00 it just gets stuck and puts the deck into pause
    7.the only way to get out is to cmd-period
    8.then the system “Quits”
    9. from here on out everytime i go into Batch Digitize it immediately Quits.
    Work arounds I have tried with no success-
    10. Trashed Prefs
    11. relogged tape #2 to a new bin
    12. made a new project file and then copyed the new bin with tape 2 into it
    13. opened “log & capture” and dragged each clip in and selected “capture clip”
    14. qued the clip, press play, and hit “capture now”
    everything results in a Unexpectedly Quit message!!!!
    Additional notes-
    15. I use the apple codec via FW w/ the Sony Firewire control. I only use the BMD card for monitoring on a HD monitor
    16. I have used the FW800 Big Disk Extremes with great success. 10- 30 min. shows without a glitch
    Any help is much appreciated!
    Carlos Prio
    field dominance
    prio(at)fielddominance.com
    305/971-7037 ext. 208
    cell. 305/785-7746
    Miami, FL
    G5 Dual 2.0 w/ 2.5 gigs of ram, 160hd
    OSX 10.4.3
    FCP HD 5.0.4
    Lacie 320 & 1T d2 extremes
    BMD HD w/ Multibridge HD
    Cinema Display
    100a, fx1, hc-1, and waiting for the HVX200
    Carlos Prio replied 20 years, 4 months ago 1 Member · 1 Reply
  • Carlos Prio
    January 5, 2006 at 10:48 pm
    Believe it or not????
    I noticed that all my troublesome clips had a “/” in the name… example- “front/1”. I name a shot then add the “/” (slash) and allow FCP to change the # automatically. So, my clip names look like this- “front/2, front/3, etc… So, I went in and changed all the names and viola!!! Digitizing Success!!!! Not a glitch!!!
    Thanks to everyone in this forum!
    Carlos Prio
    field dominance
    cell. 305/785-7746
    Miami, FL
    OSX 10.4.3
    FCP HD 5.0.4
    Cinema Display
