Activity Forums Apple Final Cut Pro Legacy batch digitise
  • Posted by Steven Kirkby on April 19, 2007 at 12:54 am
    Hey there,
    I’ve got two hours of rushes…but i only want to use the clips that i edited on the sequence which is 8min in length
    How do i batch digitize only those clips used in my sequence not all my rushes?
    cheers
    Andy Mees replied 19 years, 5 months ago 2 Members · 3 Replies
  • Andy Mees
    April 19, 2007 at 2:41 am
    select the sequence in the browser and choose “Batch Digitise” from the menu
    (note: unless you use media manager first to “create offline” w/ “delete unused media” then this method will want to digitise the full extents of the source clips used in the sequence)
  • Steven Kirkby
    April 19, 2007 at 7:12 am
    thanks mate…. but it is from a EDL we did the offline on a avid and want to master it on final cut??????
    “”Hurry up and render!!!”
  • Andy Mees
    April 19, 2007 at 8:31 am
    surely its the same thing tho…
    first, import the edl into FCP
    then select the sequence generated from the edl
    then as above, no?
