Activity Forums Adobe Premiere Pro batch deleting every second frame in a video
  • batch deleting every second frame in a video
    Posted by Annie Briard on November 18, 2011 at 8:22 pm
    Hi there,
    I have a stop-motion related question. Usually when making stop-motions I use a still camera, but for time-saving purposes for quick pre-production tests I shot the animation full on with a video camera. My question is, does Adobe Premiere have a built-in way to throw out every second frame in a clip? I’m fine with doing it manually but it’s a long process, so I figured I’d check in case anyone had any ideas. It would save me hours of work, so thanks for any suggestions!
    best,
    Annie
    Annie Briard replied 14 years, 9 months ago 2 Members · 2 Replies
  • Robert Brown
    November 18, 2011 at 10:33 pm
    Unless I’m not following you the easiest way to do that would be to just play the clip at 200% and voila every other frame is gone. Also Sapphire has a freeze frame plugin that will hold frames by whatever interval. If you put in the value of 2 it would hold the first frame and play it twice and then skip the next frame and then hold the third one twice etc.
    Robert Brown
    Editor/VFX/Colorist – FCP, Smoke, Quantel Pablo, After Effects, 3DS MAX, Premiere Pro
    https://vimeo.com/user3987510/videos
  • Annie Briard
    November 18, 2011 at 10:58 pm
    Rereading my post I see I wasn’t that clear but your Sapphire plugin option sounds perfect. I also experimented with the posterize time effect and it’s getting me that choppy look.
    thanks Robert!
