Activity › Forums › Adobe Premiere Pro › Batch conversion
  • Batch conversion
    Posted by Pat Mcgowan on August 16, 2006 at 2:06 pm
    We are working on a NTSC widescreen project and have digitized HD footage in another project. I have about 100 clips that I need to bring int the NTSC project.
    Any ideas on how to do a batch conversion to NTSC anamorphic widecreen?
    Steven L. gotz replied 20 years, 1 month ago 2 Members · 3 Replies
  • Steven L. gotz
    August 16, 2006 at 10:12 pm
    There really isn’t a need, is there? Just import into Premiere Pro, and set the Motion effect’s Scale to the right size. Or set your project to automatically scale images to the frame size.
    Steven
    https://www.stevengotz.com
  • Pat Mcgowan
    August 17, 2006 at 12:22 pm
    Won’t this slow down an SD project?
  • Steven L. gotz
    August 18, 2006 at 10:22 pm
    Somewhat. But if you want to pan and scan it comes in handy. Otherwise, just export out a SD frame size from the HD project and use that in the SD project. But that would be time consuming as well.
    Steven
