Activity › Forums › Apple Final Cut Pro Legacy › Batch conversion – image sequences to Quicktime
  • Batch conversion – image sequences to Quicktime
    Posted by Christopher Tay on January 3, 2007 at 3:03 pm
    Does anyone knows if there are any batch conversion software that can convert an image sequences, ie. JPEG, TIFF to Quicktime format ?
    Currently I am using Quicktime Pro which works fine but I’m looking for a more flexible way to do this conversion process.
    -chrispy
    Christopher Tay replied 19 years, 9 months ago 5 Members · 9 Replies
  • 9 Replies
  • Jeremy Garchow
    January 3, 2007 at 4:19 pm
    After Effects? Not sure what your color requirements are, but it’ll work.
    You can also open more than one image sequence in quicktime at a time as well as export more than one at a time. Open the sequences, choose export to quicktime and then set up the parameters to what you want, then switch to the next open sequence, hit Apple-e (export) then hit return. Not exactly a batch but it’s faster than waiting one at a time.
    Jeremy
  • _Adam_ Create COW Profile Image
    _adam_
    January 3, 2007 at 5:37 pm
    Shake is probably what you’re looking for. It can do all that and a whole lot more.
  • Peter Wiggins
    January 3, 2007 at 5:48 pm
    Why buy Shake? Motion comes in FCS.
    Peter
    _adam_
    January 3, 2007 at 6:07 pm
    Motion can turn image sequences into quicktimes?!?!? Man, I really gotta read the manual for that program some day.
  • Peter Wiggins
    January 3, 2007 at 7:41 pm
    Yes, the little button on the bottom of the right of the file browser with the series of rectangles on it displays image sequences as one file.
    Drop the image sequence onto your timeline & export
    Peter
    _adam_
    January 3, 2007 at 11:14 pm
    Woah, it totally works! I seriously have to start playing around with this program more and figure out all the stuff you can do with it.
  • Alan Lacey
    January 4, 2007 at 11:26 am
    I still think FCP’s lame not being about to import image sequences directly though.
    Alan
  • Jeremy Garchow
    January 4, 2007 at 4:21 pm
    Found at hdforindies.com:
    https://pomfort.com/silverstack/
    Jeremy
  • Christopher Tay
    January 6, 2007 at 3:30 am
    Thanks Jeremy…looks like a great app. Will try out the beta version.
    Now…Apple should just buy them and integrate it into its Pro Apps.
    -chrispy
