Activity Forums Adobe After Effects Batch Change Resolution – possible? necessary?
  • Batch Change Resolution – possible? necessary?
    Posted by Klaus Boehmer on May 8, 2016 at 3:12 pm
    I have a main composition which consists of two or three dozen “sub-compositions”. By default, they are all set to “quarter resolution”. Now I have two questions:
    In order to achieve the best resolution, is it necessary to all change all resolutions (meaning all “sub-compositions” resolutions, too)? Or is it sufficient to simply alter the main composition?
    If it is indeed necessary to change all resolutions, is there is a script to batch-job the task? All scripts I have found so far allow me to alter various other composition settings but not the resolutions.
    thanks
    Kalleheikki Kannisto replied 10 years, 4 months ago 2 Members · 1 Reply
