Activity Forums Apple Final Cut Pro Legacy Batch Change markers
  • Batch Change markers
    Posted by Matt Gerard on August 6, 2008 at 9:47 pm
    I need to be able to quickly change markers from standard markers to DVD Chapter markers. Is there a quick way of doing this? I’m tlaking lots of markers, having to do each one by hand is quite painful.
    Any Ideas?
    Matt
    Its more fun to ride a slow motorcycle fast than a fast motorcycle slow…
    Ben Scott replied 18 years ago 2 Members · 1 Reply
  • Ben Scott
    August 6, 2008 at 10:09 pm
    my best idea is to export out XML
    open the XML in a text editor like text wrangler or bbedit
    then work out the code for a chapter marker compared to a normal marker
    then use some sort of find replace possibly with Grep (check Wikipedia if not a word that makes sense)
    then reimport XML to project and export out to compressor
    Check my podcast at https://cowcast.creativecow.net/final_cut_pro/index.html
    or my site at
    https://www.benscottarts.co.uk/ – – – – – – – – –
