Activity Forums Apple Final Cut Pro Legacy Batch Center Audio Tracks
  • Batch Center Audio Tracks
    Posted by Jason Mckee on December 9, 2009 at 3:50 am
    Is there a way to batch center all audio tracks in a project. I know how to individually do each clip by bringing it up into the viewer and changing the pan from -1 and 1 to both zero but I need to do this to thousands of clips. thanks in advance.
    -jm
    Kevin Monahan replied 16 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • David Roth weiss
    December 9, 2009 at 4:38 am
    You can simply center pan one audio clip, then select that clip in the timeline, copy it, then select all clips you want center panned and paste attributes, then choose Audio Attributes and check Pan.
    Be aware, center panning right and left channels will “sum” the two together, thus significantly raising the levels.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Matt Lyon
    December 9, 2009 at 6:19 am
    you can also select all the clips you want to center and press ‘control-.’ (control and period).
    Look in the “modify>audio>” submenu for lots of handy shortcuts…
    Matt Lyon
    Editor
    Toronto
  • Jason Mckee
    December 10, 2009 at 12:29 am
    if this worked this would be exactly what we need but on our system this hasn’t worked. any ideas why it isnt? everything i read says that the control period shortcut should work as a batch but its only working for single clips. not sure why. thanks in advance.
  • Matt Lyon
    December 10, 2009 at 5:27 pm
    Sorry Jason, I’ve never seen that before so I don’t know if I can help. It works for me on several different systems I’ve tried. Have you done the usual troubleshooting stuff: repair permissions, trashing prefs, running software updater, etc? You might need to re-install the software if all else fails.
    Matt Lyon
    Editor
    Toronto
  • Kevin Monahan
    December 10, 2009 at 7:00 pm
    I just do it in the pan browser column. Simple, fast and done before you even begin editing.
    Kevin Monahan
    60 Blu-ray Templates for Final Cut Studio 2009
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Matt Lyon
    December 10, 2009 at 9:18 pm
    Hey Kevin, forgive my obliviousness here 🙂 but is a new column added to the browser in FCP 7? I can’t find it in my v6.0.6 copy.
    Matt Lyon
    Editor
    Toronto
  • Kevin Monahan
    December 10, 2009 at 10:27 pm
    My bad, thought we had that as a column. Feature request time. There should be an easier way to do it.
    Kevin Monahan
