Activity › Forums › Adobe Premiere Pro › Batch Capture timecode reverts to 0:00:00:00
  • Batch Capture timecode reverts to 0:00:00:00
    Posted by Bret Hampton on April 28, 2012 at 5:46 pm
    I’ve captured digibeta clips with my Aja Kona card using the tape timecode and seemingly at random some clips retain their source timecode while others revert to 0:00:00:00 as inpoint. I really need to retain the original timecodes to confer with the producer.
    Does anyone know why this happens? I’ve tried changing the Aja serial control options in the Premiere capture window, the Aja control panel settings for timecode (LTC, VITC, etc). Sometimes the clip is fine the first time I capture, other times have to keep trying several times before it works and other times not at all.
    Bret Hampton replied 14 years, 5 months ago 2 Members · 3 Replies
  • Doug Beal
    April 30, 2012 at 7:52 pm
    not sure what you’ve got going on there but if you can ID a frame on tape and id the frame in the capture you can modify TC and set it to be the code you want.
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
  • Doug Beal
    April 30, 2012 at 7:53 pm
    Duh I got here from decks and vtr’s and assumed you were in FCP my bad
    db
    Doug Beal
    Editor / Engineer
    Nashville TN
  • Bret Hampton
    April 30, 2012 at 11:31 pm
    No problem, Doug
