Activity Forums Apple Final Cut Pro Legacy Batch capture stopped working in FCP 5
  • Batch capture stopped working in FCP 5
    Posted by Dorit Grunberger on January 17, 2008 at 7:09 pm
    This is a repost because I’m sad nobody responded the 1st time
    Greetings … we’ve never had this problem … While attempting the batch capture, FCP does not seem to recognize the appropriate time codes for each logged clip. It starts capturing several seconds after the mark in point, and continues to capture for minutes (4-5!) past the mark out point. Same problem occurs when capturing one logged clip. I can, however, capture now with no apparent problem. Capturing DV NTSC 48kHz Advanced (2:3:3:2) Pulldown Removal. Any ideas?
    Thanks in advance!
    Dorit Grunberger replied 18 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
