Activity Forums Apple Final Cut Pro Legacy Batch Capture Settings not Cooperating (NDF vs. DF)
  • Batch Capture Settings not Cooperating (NDF vs. DF)
    Posted by E-money on March 23, 2007 at 5:00 pm
    Every time I get ready to batch capture footage that has already been logged with in and out points, FCP sends me a warning saying I’m about to “capture non-drop-frame media to a drop frame clip”. I know my media is NDF and I set all of my settings and preferences for NDF and I can’t figure out why FCP still thinks my clip settings are DF.
    I’v changed my settings in every place i can think of.
    This issue is driving me crazy because I can’t digitize until I figure out where the issue lies.
    E-money replied 19 years, 5 months ago 2 Members · 2 Replies
  • Aconover
    March 29, 2007 at 8:01 pm
    I’ve been having this same problem as well for a long time. All I’ve been able to figure out is that earlier dot-versions of Final Cut don’t have the problem, and that it’s definitely a bug, because if you check the clip settings it will say the clip is NDF as well. I believe that if you were to log and capture 50 clips, as the tape goes on the in and out points of the captured clips become more and more inaccurate — I’ve worked around it by using Capture Now and breaking the clip up into subclips. However, this does make recapturing later (if you want to up-rez, say) a tricky business — sometimes your clips will be improperly aligned (because of in-out drift) and you’ll have to go readjust them. Unfortunately, I have not found a real fix — after hours of Googling for the past few months, I’ve given up and am just waiting for the next revision to hopefully fix the problem.
  • E-money
    March 29, 2007 at 9:08 pm
    well at least i know i’m not alone. i actually asked an Applecare person about it this morning and he suggested (and i haven’t tried this yet) that i go to USER PREFERENCES- GENERAL- and uncheck the first four boxes on the right-hand side) he said that might be confusing FCP into thinking the clip is DF.
    i just tried to up-res this morning (from SD to our original HDV material) and the in and out points were (as i had feared all along) not quite accurate with what I had cut. after i thought i had fixed all of the video to sync up with my audio mix, upon export, everything was out of sync. just another mystifying cog in the wheels of FCP & HDV.
