Activity › Forums › AJA Video Systems › Batch Capture Reporting Error
  • Batch Capture Reporting Error
    Posted by Christopher Tay on May 13, 2006 at 12:58 pm
    Just wanna check if anyone has encountered this.
    One an FCP 5.0.4 (OSX 10.4.3) system running Kona2 with 1.2.2 driver, when batch capture is done, instead of reporting as DONE, it reports as READY, which if unconsciously you hit the Enter key on the keyboard, it will repeat the batch capture process again. However if you click CANCEL, it will close the batch capture report window and the clips are actually linked to the captured media.
    I’ve trashed FCP preferences and it still behaves the same.
    Anyone seen this behaviour before ?
    -chrispy
    Jared Picune replied 20 years, 4 months ago 2 Members · 1 Reply
  • Jared Picune
    May 13, 2006 at 4:48 pm
    I had the same thing happen at some point a while back. I am now running 5.1 on 10.4.6 and do not have that issue.
    Jared
    Idea Spring Editing, Inc.
    Denver Final Cut Pro UG
