Activity Forums Adobe Premiere Pro batch capture problem
  • batch capture problem
    Posted by Brett Nelson on May 4, 2006 at 8:07 pm
    Hello,
    This is might be a dumb question, but I’ve searched the archives and didn’t find an answer.
    I’m batch capturing a series of hour long clips (I believe they were all created in PPro 1.5 and now being used in 2). When I Batch Capture I get this message in a capture log, “Capture Failed: Device not found”. But the device shows up and is working. These tapes were captured with less than 5 seconds of heads. Is this the problem? If so, why don’t I get the “Bad timecode range”? Is there a way to change the timecode range without ignoring capture settings? Or is it another problem altogether?
    Brett
    Brett Nelson replied 20 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
