Activity › Forums › Apple Final Cut Pro Legacy › Batch capture problem with HDV
  • Batch capture problem with HDV
    Posted by Ryan925. on February 19, 2007 at 3:17 pm
    I’m trying to set up a batch list to capture using a Sony HVR-Z1U. Even if I only have 1 clip logged in the bin all it does after I push continue is it goes back to the logging bin and shows the clip as offline. The capture window never shows up. I am able to capture using capture now. And I am also able to batch capture regular DV clips just fine. I’m capturing to a local hard drive. FCP 5.0. Also I’m capturing at 1080i60.
    Anybody know why batch capture doesn’t work with HDV?
    Mark Maness replied 19 years, 7 months ago 4 Members · 6 Replies
  • Walter Biscardi
    February 19, 2007 at 3:19 pm
    [Ryan925.] “Anybody know why batch capture doesn’t work with HDV?”
    I’m not sure FCP 5.0 works correctly with HDV. FCP 5.1 I believe was the first to offer support for that format.
    I’m capturing now from our Sony M15U HDV deck with no problems and haven’t had any problems with it going on 6 months now.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Ryan925.
    February 19, 2007 at 4:19 pm
    I have updated FCP to the latest version and still can’t batch capture.
  • Walter Biscardi
    February 19, 2007 at 4:41 pm
    [Ryan925.] “I have updated FCP to the latest version and still can’t batch capture.”
    REally don’t know then, you’ll have to wait for someone with that camera to chime in. We don’t use cameras as VTR’s here, sorry.
  • Chris Borjis
    February 19, 2007 at 5:00 pm
    Do a google for “trashing your preferences” this could fix the problem.
    Search the apple fcp support forums as well.
    You may need to re-install.
    The capture utility for HDV in 5.1 is different than the regular one used.
  • Chris Borjis
    February 19, 2007 at 5:03 pm
    [Borjis] “The capture utility for HDV in 5.1 is different than the regular one used.”
    sorry that should have read 5.x.x
    I have the upgrade to 5.1.2 but have chosen not to run it yet as 5.04 works perfectly fine for now. It definitely supports HDV capture.
  • Mark Maness
    February 19, 2007 at 9:37 pm
    Two things to try…
    1. Trash your preferences using FCP Attic or something like it.
    2. It sounds like the problem with Quicktime that Apple is aware of… Go to this site and do what it says. https://docs.info.apple.com/article.html?artnum=301852
    Give this a try.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
