Activity Forums Apple Final Cut Pro Legacy Batch Capture Logging Template question
  • Batch Capture Logging Template question
    Posted by Chris Borjis on March 7, 2007 at 11:28 pm
    I have the logging template by Larry Jordan.
    Its not working because the instructions don’t quite make sense.
    3)IMPORTANT: Select Column E, Copy, then PASTE SPECIAL using VALUES
    Paste special into what? The same column, over itself?
    the timecodes in the yellow column have no colons in them they
    are all straight numbers for some reason.
    Chris Borjis replied 19 years, 6 months ago 1 Member · 1 Reply
  • Chris Borjis
    March 8, 2007 at 4:38 am
    found an easier way.
    export a batch list
    right click, open with excel (opens right up, no prompting for tab delimited formating)
    edit timecodes, save, import to fcp, voila!
