Batch capture is not working :( please help
Hi
I have logged some 23 HD-DVCPRO tapes using DVCPRO HD 720P 30. Then decided to capture them using Blackmagic HDTV 720P 59.94 8 bit.
The problem is when I use the batch capture command it seems to find imaginary timecode breaks then split the clip into bits 🙁
However when I check the tape there are no tc breaks and when I use capture now it captures the whole clip without any tc breaks.
This is a large project and I dont have time to capture everything one by one.
If anyone might have an idea as to what might be causing this please reply.
Thanks.
Zee.
