Activity Forums Blackmagic Design Batch capture in Premiere – some capture problems
  • Batch capture in Premiere – some capture problems
    Posted by Donat Van bellinghen on September 16, 2005 at 8:01 am
    I’ve got a working setup consisting of a Supermicro P4SCT-II, a sata Raid, with a Decklink Pro SD.
    The system works quite well for over 10 months. Capturing and exporting is reliable expect that I have a problem when batch capturing from within Premiere Pro 1.5. Some of the captured clips have “blocks” in them, the kind of blocks you see when fast-forwarding a tape (Digital Betacam).
    It’s nasty because it happens randomly, so if I batch capture 100 clips maybe 5 clips are going to be bad. That means that I then have to check everything closely.
    Is that problem known or experienced by others as well ?
    Donat
    Donat Van bellinghen replied 20 years, 11 months ago 3 Members · 3 Replies
  • Oscar G.
    September 16, 2005 at 9:05 am
    hy donat
    In case of, try a preroll of 10 second. Maybe it could arrange your issue.
    We have two computer with a decklink extreme.
    In one there is no need to do this (the 10 sec of preroll), but with the other yes because it could append sometime missmacth of frame/timecode while exporting or capturing vid
  • Pentti Kakkori
    September 16, 2005 at 1:58 pm
    I had same kind of problem, here is link
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=124&postid=793578&archive=T
    This was in march some drivers ago, I haven’t had same kind of work since. I think that Premiere (or Decklink tape control inside Premiere)don’t get feedback from VTR that it haven’t syncronized yet. I think Oscar’s propotion to increase preroll time to ten seconds is good workaround.
  • Donat Van bellinghen
    September 20, 2005 at 8:01 pm
    Thanks to both of you, I’ll use the 10sec preroll workaround.
    Regards
    Donat
