Activity Forums Apple Final Cut Pro Legacy Batch Capture Handles
  • Batch Capture Handles
    Posted by Laurie Kain on September 5, 2009 at 3:13 am
    I think you all are awesome to lend you expertise. I have been following Cow for many years and found it to be a life line on many occasions. Thanks for being there.
    I experienced an interesting problem using Final Cut 6.0.6. When batch capturing, the handles that I had set to 5sec. automatically changed to 6 minutes as soon as they were added to the capture cue. If I had the handles turned off it still added 6 minute handles to the clips in the capture cue.
    It only occurred on one tape of several tapes I have captured. Has anyone experienced this?
    I am capturing SD 24p Advanced,
    Capture Setting: DV NTSC Advanced (2:3:3:2) Advanced Pulldown Removed,
    Video was shot with a Panasonic AG HVX 100.
    I was not the photographer so my information is limited as far as the camera specs go.
    PowerBook G4, OS 10.4.11
    1.67 GHz, 2GB DDR2 SDRAM
    Laurie Kain replied 17 years ago 1 Member · 0 Replies
  • 0 Replies
