Activity › Forums › Adobe Premiere Pro › Batch Capture and Firewire
  • Batch Capture and Firewire
    Posted by Alex Udell on April 4, 2006 at 10:06 pm
    Hi All…
    I’m doing some workflow testing and have run across arather interesting issue using Premiere Pro 2.
    Capture a clip using firewire: dv or HDV format HVR-M10U and DSR 11 repectively
    Mark it.
    Drop the clip on a timeline.
    Make the clip in the Project window offline and delete the media.
    Batch Capture the clip in the Project window.
    The captured frames do not match the orignal frames.
    The timecode matches, but the frames are off by varying amounts across several tests.
    Is this a known Premeire Bug?
    Thanks…
    Alex
    Alex Udell replied 20 years, 5 months ago 1 Member · 1 Reply
