Activity › Forums › Adobe Premiere Pro › Batch Capture and Changing what is captured
  • Batch Capture and Changing what is captured
    Posted by Kevin Christopher on August 29, 2006 at 6:48 pm
    I just got through logging an hour of footage, and noticed that some of my clips are set for audio only. So I thought double click and change it, but this option is greyed out. Any way to change them after they have been logged?
    Kevin
    Adam Fischer replied 20 years, 1 month ago 3 Members · 3 Replies
  • Dave Friend
    August 29, 2006 at 7:01 pm
    Kevin,
    Right click the entry and select edit>log entry to “load” that event in the upper section of the logger. When you have made your changes press the re-log button.
    This is only an option if the clip has not yet been captured.
    Dave
  • Dave Friend
    August 29, 2006 at 7:08 pm
    Oops, wrong forum. I was talking about an entirely different app. What I said has no bearing on what you’re trying to do.
    Sorry.
  • Adam Fischer
    August 30, 2006 at 12:07 am
    Try a search of the archives in this forum. I had the same problem and found the solution on here but now I can’t remember how I did it!
