Activity Forums Apple Final Cut Pro Legacy batch capture
  • Posted by Quaadnyc on September 13, 2006 at 7:15 pm
    has this happened to anyone:
    log a bunch of clips, highlight, batch capture. Starting with clip one, all are captured. you can watch it happen. then instead of the “finished” message, you get the “ready to capture” window. if you click ok, it will start the whole process again. if you click cancel, it will tell you capture was aborted. all the clips show up in the been as linked to media except the first one. If you try a batch capture of that one, the same thing will happen. but if you click cancel the second time the “capture ready” window comes up, there’s a chance that your media will be on the drive. but it’s icon will be a file, not the quicktime icon.
    i’ve worked around this a few times, in the meanwhile, trashed the prefs, etc. the issue remains.
    i’m baffled.
    quaad NYC
    G5 Dual 2.7 GHz Power PC
    4Gb RAM
    FCP 5.04/Blackmagic Decklink HD PRO
    Quaadnyc replied 20 years ago 1 Member · 0 Replies
  • 0 Replies
