Activity Forums Apple Final Cut Pro Legacy Batch Captue Question
  • Batch Captue Question
    Posted by Angela Boyd on April 16, 2005 at 4:15 pm
    I have already gone through and logged clips from about 15 differnet mini dv tapes. The first reel that I inserted worked fine..all 14 clips were captured succesfully. Now, every other tape is giving me an error that says..Nothing was captured as there is no video….I did nothing different then the first time. I double checked to make sure that the tape matched the reel tht I have labeled on my logged clips, and made sure that my settings were turned off, as far as aborting on timecode breaks and dropped frames. Anyone know why i am getting this error message????? Thanks…Angela ( Inline Studios)
    Matthew Brunn replied 21 years, 5 months ago 2 Members · 1 Reply
  • Matthew Brunn
    April 16, 2005 at 9:03 pm
    I’ve had this happen but it was so long ago I can’t remember what I did. Have you tried doing one clip at a time? Have you tried doing a clip capture from one of the tapes just as a test? When the computer is “capturing” do you see the video on the computer screen? Just a little test to see if it is a FCP problem or a “system” i.e. the hardware connected to the computer, problem. Try different levels of capture. NOW, CLIP and then BATCH and see where it falls down. Do you capture from more and just DV? Such as a RS-422 for deck control or a Voodoo card for video. I’m sure you have check most, if not all of these. How about trashing Prefs? Hope this helps-
