Activity Forums Adobe Photoshop Batch Adjust Color for 50 images PS CS2.
  • Batch Adjust Color for 50 images PS CS2.
    Posted by Bob O dell on December 11, 2006 at 12:29 pm
    How do I. Batch Adjust color PS CS2.
    I have 50 jpg images in one file on my PC.
    I want to change the color, “Hue-Saturation Filter” of all images at one time.
    Can I do this?
    Do I need a plug-in to do this?
    Thanks Bob
    Tim Kurkoski replied 19 years, 9 months ago 2 Members · 1 Reply
  • Tim Kurkoski
    December 11, 2006 at 10:15 pm
    If you want to apply the same adjustments to each image, then yes, this is relatively easy. Create an action that makes the adjustment, then run a batch with that action.
    If you’re unfamiliar with creating actions or running a batch, I’d recommend you look up those terms in the Help files first. It’s not terribly hard, and the Help files explain it better than I can. If you have more questions after reading and trying it out, certainly post back here and we’ll see if we can straighten you out.
