Activity › Forums › Adobe Premiere Pro › Batch adding file extensions
  • Batch adding file extensions
    Posted by Nathan Hall on March 12, 2010 at 4:15 pm
    I have a project that requires me to go through years of footage but I’m running into a problem with file extensions. I didn’t shoot any of the footage and for whatever reason a ton of the clips have no file extension. I can open them in final cut pro but I prefer working in premiere for various reasons. When I drag the clips into premiere cs4 it gives me “file format not supported”. My question is… is there a way to batch add file extensions? And if so… How do I do that? I’ve added the .mov file extension to several clips and then they import and play fine in premiere but I don’t want to have to do that to 4 million clips one at a time.
    Thanks for any tips you can give me!
    https://www.anchormedistudio.com
    Chris Buttacoli replied 16 years, 6 months ago 3 Members · 5 Replies
  • Mike Cohen
    March 12, 2010 at 6:14 pm
    download the free utility “bulk rename utility” – just google it – saves me countless hours.
    You can not only add or change extensions, but change the names, replace characters etc. I use it a lot when working with powerpoint slides. They all come out as Slide1.BMP, Slide2.BMP etc – I add a prefix, such as Jones_ to the lot of files in a lot less time.
    Mike Cohen
    PS – This is a PC utility.
  • Nathan Hall
    March 12, 2010 at 7:49 pm
    Thanks Mike, I’ll give that a shot. People like you are why the Cow is such a great place!
  • Chris Buttacoli
    March 15, 2010 at 5:40 pm
    Or you can use Adobe Bridge if you have the CS bundle.
  • Nathan Hall
    March 15, 2010 at 8:49 pm
    I have used bridge for batch renaming but I think –unless I’m missing something– it doesn’t rename file extensions.
  • Chris Buttacoli
    March 22, 2010 at 5:04 pm
    Absolutely does!!! [CS3 version is what I have]
