Activity Forums Adobe After Effects Basic Text Animator
  • Basic Text Animator
    Posted by John Sappo on March 25, 2021 at 2:48 pm
    Hi-
    this might seem so basic to some but I have a simple text animator that fades the text on screen. See image attached.
    The fade moves to the right, and after the text is on screen for a bit, i want it to reverse the way it appeared. When i keyframe the offset value back to the starting value the fade starts from the left again. how can i reverse this?
    Thank you kindly in advance.
    John Sappo replied 5 years, 6 months ago 3 Members · 4 Replies
  • Patrick Grossien
    March 25, 2021 at 2:59 pm
    Try not using the offset, but the start/ end values for fade in/out stuff. The offset is if you set a range and want to move text parts … something like that: ooooooOOOOoo — oOOOOooooooo
  • Joe Burke
    March 25, 2021 at 3:01 pm
    Hi John,
    I was able to get this to work by doing the following.
    – set the opacity to 0%
    – Start=0
    -Offset=0
    – Keyframe the End from 100% to 0% then back to 100%
    See attached AE file.
    Is this want you are wanting to do?
  • John Sappo
    March 25, 2021 at 3:35 pm
    WOW! Thanks for the fast replies, and test file you provided Joe!
    It’s very close.
    The start / end values makes more sense. I will adjust that.
    Thank you both. ?
  • John Sappo
    March 25, 2021 at 3:59 pm
    Joe-
    I added a line of text to the test file and set up the keyframes similar to the example you provided.
    Two things:
    1) I can’t achieve a similar fade, the text just pops on in this setup. This is kinda cool, but how I do preserve it if desired?
    2) The text fade appears on screen from left to right, how I get it to fade out from left to right also?
    I re-attached the test file with my added line of text.
    Thanks again in advance!
