Activity Forums Maxon Cinema 4D Basic selecting and modeling
  • Basic selecting and modeling
    Posted by Stanomatic on August 30, 2007 at 6:26 pm
    I brought in an illustrator type outline to extrude. It’s a 3 word movie title stacked vertically.
    Done this so far:
    Function > connect
    Extrude
    Looks great, but now I want to texture, animate etc… each word.
    How do I select one word to animate it?
    How do select just the faces to color them?
    Do I have to go back to square one an import each word separately?
    Can’t I duplicate 3 times and delete what I don’t need as this would be better work flow?
    Adam Trachtenberg replied 19 years ago 2 Members · 1 Reply
  • Adam Trachtenberg
    August 30, 2007 at 11:58 pm
    You can break up the spline with Function>Explode Segments, then group them by word and connect again. Or, you could animate the words by animating the spline points, but that would be a bit of a PITA.
    You can restrict materials to extrude objects’ caps and roundings by typing (respectively) C1, C2, R1, or R2 into a material tag’s restriction box.
