Activity Forums Maxon Cinema 4D Basic – Select / Hide / Show objects
  • Basic – Select / Hide / Show objects
    Posted by Stanomatic on September 7, 2007 at 9:30 pm
    Where can I find a tutorial on the following?
    What’s workflow for selecting objects and polys and points. How do I switch tools quickly for selecting and hiding?
    Object Manager hi-light Polygon Selection Tag > Attribute Manager > Select and Hide Others, doesn’t do anything. Why? How do I select just the extruded sides of my logo / text object and apply a color?
    Do I really have to select that tiny gray visibility dot in the object manager show / hide objects and their parts? Is there a key command to hide / show selected objects, polys, etc…. What’s the best workflow?
    Related Interface Colors and Fonts
    Object Manager > Green Check mark indicating visibility
    Is there a way to make it’s color darker? It doesn’t show up very well using the Darkglow interface scheme. How come the green check / red X doesn’t show at all on polygon objects?
    How do I re-dock a floating palette?
    Stanomatic replied 19 years ago 3 Members · 3 Replies
  • Adam Trachtenberg
    September 8, 2007 at 2:53 pm
    Not being critical here, but all of this is covered in the manual.
    You can use the Command Manager to assign shortcut keys to virtually any function in Cinema. By default, the space bar switches between the live selection tool and the last tool you used.
    > Attribute Manager Select and
    It does here.
    You can’t select polys of generated objects unless you make them editable, but you can still apply separate textures to caps/sides/and roundings by typing C1 (cap 1), C2, R1 (rounding 1) and R2 in a material tag’s restriction box.
    You have other options, such as assigning shortcut keys or assigning objects to layers and using layer visibility, or using filters.
    I believe you would have to assign your own.
    >Object Manager > Green Check mark indicating visibility Is there a way to make
    >scheme.
    This is an icon, so you would have to adjust the bitmap. All of the icons are in one .tif file in your [Cinema]\resource\icons folder.
    >objects?
    Because the check mark/x turns on and off generator objects — not editable poly objects.
    grab it by the icon in the upper left corner and drag it wherever you want.
  • Yoondo
    September 10, 2007 at 2:25 am
    You forgot to say “please”.
    Seriously, I know this is a forum, but you need ask for help, not demand for help.
  • Stanomatic
    September 10, 2007 at 4:53 pm
    Thanks Adam. The manual I was using was the pdf on the computer. I have since found a tutorial book that comes with the manuals in another office within my dept. Otherwise I wouldn’t have known to check. CG4LIFE, thanks for reminding me of best practices.
