Activity › Forums › DVD Authoring › Basic question re:Lt/Rt
  • Basic question re:Lt/Rt
    Posted by Adams Wood on February 15, 2010 at 6:39 pm
    My soundmixer has given me an Lt/Rt mix two .wav files (one L, one R) and I’m not sure how to use them to create a DVD in DVDSP.
    The only thing I can think of is to add surround, assign them Left and Right, and hope for the best, but is that right?
    cheers.
    DVD SP 4
    Compressor 3
    Adams Wood replied 16 years, 7 months ago 3 Members · 7 Replies
  • 7 Replies
  • Michael Sacci
    February 15, 2010 at 8:20 pm
    You have a the different parts of a stereo stream, that does not make for surround. The first thing you need to find out, are these streams panned? I would bring them into a audio program and make them a stereo file and then encode that as 2.0 ac3.
  • Adams Wood
    February 15, 2010 at 8:56 pm
    Can I just put them in FCP and pan them?
  • Michael Sacci
    February 15, 2010 at 9:56 pm
    sure, then export it as aiff stereo.
  • Bill Stephan
    February 16, 2010 at 5:25 pm
    Lt/Rt is Dolby Pro Logic 1 or 2. Dolby PL-1 format has 3 front channels plus 1 surround channel. Dolby PL-2 format has 3 front channels plus 2 surround channels. In both cases, the .1 (LFE) channel is optional. Dolby PL is fully compatible with stereo applications.
    When you encode your .ac3 audio file, select Dolby 2.0, and look for the settings “not surround encoded/surround encoded/not indicated.” Check “surround encoded.” You can do this in Compressor or in any other Dolby encoding application.
    When played through a surround audio system, you should hear surround content, although it will not be as good as 5.1 encoded from discreet tracks.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Adams Wood
    February 16, 2010 at 6:10 pm
    Thanks a lot for the help, Bill.
    My immediate problem is pretty basic, I think – I’m using Compressor and I need to know how to encode the 2 wav files as an .ac3, together. Or do I have to somehow make them one file before I encode them?
    Thanks again,
    Adams
    Mac Pro 10.5.5
    DVDSP 4
    Compressor 3
  • Bill Stephan
    February 18, 2010 at 6:06 pm
    You can import individual .wav files for 5.1 surround in Compressor, but I never tried it with stereo. (Most of the .wav files that come here already have 2 tracks for stereo.) If there’s no way to do it, then drop the two files into either Soundtrack Pro or Final Cut Pro and send to Compressor.
    Bill Stephan
    USA Studios
    New York City
  • Adams Wood
    February 18, 2010 at 6:10 pm
    Of course – that makes sense – don’t know why I didn’t think of it. Thanks Bill!
