Activity › Forums › Adobe After Effects › Basic question regarding Mocha for AE
  • Basic question regarding Mocha for AE
    Posted by Philippe Gosselin on February 21, 2012 at 8:18 pm
    Hi all,
    I am running CS5 and for the first time I am in need of mocha to stabilize some shots. I’ve watched some tutorials and so far so good.
    The only thing I am missing is the ability to scale the shot, otherwise it will end up like this:
    https://youtu.be/TeMtqrBumHo
    What would be the way to go around this issue?
    Phil
    Ross Shain replied 14 years, 7 months ago 3 Members · 3 Replies
  • Jon Merrifield
    February 21, 2012 at 8:28 pm
    Well you may never get around the fact the you have to increase the scale once a shot has be stabilized as such. However, using the Motion Tile effect, may enable you to reduce the amount of scale increase that you have to do.
  • Philippe Gosselin
    February 21, 2012 at 8:56 pm
    So it is just a matter of scaling then?
    For some reason I was under the impression that Mocha would’ve done that when it was “rendering” the clip, thus was afraid that I may have missed a step.
    Thanks for the pointer Jon
  • Ross Shain
    February 21, 2012 at 11:59 pm
    You may want to check out mocha Pro which does have an “auto-fill” feature when you render stabilized footage, but will not work on all footage.
    reference video:
    https://www.imagineersystems.com/videos/mochapro_intro_to_stabilize/view
    Ross Shain
    Imagineer Systems
    http://www.imagineersystems.com
