Activity › Forums › Zaxwerks › basic question (I’ll try to make it confusing though)
  • basic question (I’ll try to make it confusing though)
    Posted by Chad Barnhardt on October 13, 2007 at 1:11 am
    I am trying to recreate a logo in Zax. It is a U-shape but it is squared off on the bottom. I made it one path in illustrator. It imports and extrudes in fine in Invigorator.
    The problem comes in when I want to apply materials to it. The front needs to be white with a black stroke and the side needs to be a gradient. The bottom and top need to be black.
    I can get the front to be white with a black stoke but when I do a layer map (gradient, or any material)to the side it applies it to the top, bottom and inside etc. There are no options for the top and inside in the material set-up window.
    In the material set-up window the “U” shows up as a rectangle. Is it like this for every object or do I need to do something different in illustrator to make it appear as a “U” in the set-up window. Thanks for any help.
    Chad Barnhardt replied 18 years, 11 months ago 2 Members · 2 Replies
